how to enable 40 MHz channel width in RB-711 series
hello frds
how we can use and enable 40 MHz channel width in all RB 711 boards.
i can see only 5,10,20 MHz width.
Thx
have you enabled 802.11n mode?
if u have one of this RB711A-5Hn-M/RB711-5Hn-U/RB711-5Hn-M
in HT Tab select HT Extension Channel below/above control
is it below control or above control.
Regards
depends if you want it below or above. :slight_smile:
Do a spectral scan and see if higher or lower is clearer. (If you have a card that supports it.)
/interface wireless spectral-history interface_name range=5ghz
Or do a scan if you can’t do the spectral thing.
