hi all
I use pptp service for my wireless clients
you know user name and password for each
but I want to use their mac address for more managament
thank u
hi all
thank u
what do you mean by mac filter? only known MAC addresses can connect to your AP? use the access list
I know how to add MAC addresses to the access list
but how can I prevent unknown MAC addresses from being in my
registration Table
note : am using WinBox V2.9.6
set default-authentication to no, then only addresses from access list will work.
thank you normis
I will try that
by the way
is there an idiots manual for WinBox ![]()
sorry but we don’t have a manual for winbox. but if you use the regular manual, the examples and commands are the same as in winbox (almost). you only don’t have to type the commands, but click on checkboxes and buttons.
