Hi, all,
My scenario should be simple but make me confusing.
I have a LAN and two WAN.
LAN
WAN1
WAN2
and I have a server located in LAN.
I am hoping both WAN1 and WAN2 can accept connection from internet and forward the connection to that server in LAN.
So ,I did following configuration
- all traffic from LAN goes to WAN1 and connect to internet ,by adding default route 0.0.0.0/0 to gateway of WAN1.
- add NAT masquerade for traffic to internet
- add dst-nat for WAN1 and WAN2, redirect to the server and port in LAN
then , I met following problems
- Server can get connection from internet through WAN1,and works fine.
- Server can not get connection from internet through WAN2.
- Ping WAN2 from internet, no ICMP response.
then I add following rules,
- Add mangle rule to mark routing “WAN2” for in interface WAN2
- Add route ,for Routing mark “WAN2” goes to gateway of WAN2.
After above configuration, Ping WAN2 from internet works.
But still,Server can not get connection from internet through WAN2.
Would anyone help how I can make it working?
