I have set a global variable,now I want to erase it from Mikrotik,how to do?Thanks
http://forum.mikrotik.com/t/how-do-you-clear-a-global-variable/25265/1
Still works on 4.5:
[admin@rb750g] /system script> pri
Flags: I - invalid
0 name="test" owner="admin"
policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive
run-count=0 source=
:global test "This is a test"
put $test
1 name="test2" owner="admin"
run-count=0 source=
:global test
:put $test
[admin@rb750g] /system script> run 0
This is a test
[admin@rb750g] /system script> run 1
This is a test
[admin@rb750g] /system script> env pri
# USER NAME VALUE
0 admin test This is a test
[admin@rb750g] /system script> env rem 0
# USER NAME VALUE
I see , thank you for your vivid reply.
