Hi, how to erase log created?
Saw the instruction somewhere, but forgot where…
No luck with search…
thx
thx
set store lines to 1 and then back
is this a command line or instruction??
where can i set store line?
ps: i’m using 2.9.49
thx
http://www.mikrotik.com/testdocs/ros/2.9/system/logging.php?permalink=0.3789324849770237
this is in Logging configuration. You can set the maximum number of stored log lines. Change it to 1 and then back to 100
ah .. it works thank you!
but… can it be erase just 1 or a few lines?
no
