I have real scenario that i can’t force to work. Our company have 2 seperate oficces each with it’s own internet access ISP-A and ISP-B. Oficces are connected with each other our own fiber cable. we want to configure mikrotik routers in both oficces that way that if ISP-A fails than all trafic will be passed through our fiber cable to second office and use ISP-B. and if ISP-B fails all trafic will be passed also through fiber and use ISP-A. we don’t know how to do that becouse in first scenario side B of our fiber is gateway and side A is “client” and in second scenario side A is gateway and side B is client. we can set it manualy in the event of one ISP fails but we cant make it automatic failback. Can any one help in this config?
Good question.
Trying to think conceptually.
Assuming you have one common cable over which to do this work, I would probably use two different VLANS.
At each Router, one of the vlans would be an incoming WAN connection from the other Router. Via a private subnet. on ETHERPORT XY.
At each Router the other vlan would be a LAN subnet providing DHCP service to the other router.
Something like, simplisitic, probably much more elegant ways. Create two private networks running over the common cable, and their only function is to act as a static private WANIP for the other router. R1 /interface bridge
name=BR-WAN-LAN
/interface vlan
add name=vlan11 interface=BR-WAN-LAN vlanid=11
add name=vlan22 interface=BR-WAN-LAN vlanid=22 comment=“backup wan”
add bridge=BR-WAN-LAN interface=port XY
/interface bridge vlan
add bridge=BR-WAN-LAN tagged=BR-WAN-LAN,etheportXY vlan-ids=11,22 Edit: corrected I had a type of 12 (instead of 22)
add address=192.168.11.1/24 interface=vlan11 comment='local private subnet"
add address=192.168.22.2/24 interface=vlan22 comment=“static wanip”
add address-pool=static-only interface=vlan11 name=dhcp11
/ip dhcp server-network
add 192.168.11.0/24 dns-server=192.168.11.1 gateway=192.168.11.1
add chain=srcnat action=masquerade out-interface=vlan22
/ip interface list members
add interface=vlan22 list=WAN
add distance=2 dst-address=0.0.0.0/0 gateway=192.168.22.1 routing-table=main
