how to Exclude one Website bandwidth Limit (dodear.com)
Hi Dear i am purchase RB3011 and My network scenario is WAN IP 192.168.10.1/24 DNS 8.8.8.8.
My LAN IP is 192.168.168.80.1/24.
and now configure LAN and WAN IP of my Router interface and simple nating rule and then internet is working.
Dear My Problem is i am create simple queue target=192.168.80.1/24 256/512. but queue limit on dodear.com and my requirement is how to Exclude one Website bandwidth Limit (dodear.com)
Create an address list in IP > Firewall > Address Lists. Add the IP addresses of dodear.com to an address list called “throttle”
Create a firewall rule to mark all packets inbound on wan1 except from IPs listed in this address list.. Go to IP > Firewall > Mangle. Add rule, chain = prerouting. src. address list= NOT throttle, action=‘mark packet’. New Packet Mark = throttle
Create a queue tree (not simple queue). One of the fields is “Packet Mark”.
It’s worth noting that you can’t actually limit the download speed. Speeds are only limited after the queue.
Many inbound connections will try to send packets quickly. When the queue fills, it’ll begin dropping packets. Sending devices can detect packet loss and will slow it’s transmission to reduce packet loss. This happens on a per TCP connection basis only. If you have lots of customers on your LAN, you will likely see the inbound bandwidth always higher than your queue’s limit.
Dear you don’t understand my Question I am define my question for example i am limit simple queue target 192.168.80.0/24 256K UP and 1M down then speed limit perfect but my requirement is don’t limit only one website YouTube.com target 192.168.80.0/24.
My advice i am limit simple queue everything of internet websites but don’t limit only one website YouTube.com
