hey guys i have a question my hotspot works fine in ether4 at the 10.12.0.0/24 now my pool range is 10.12.0.20-10.12.0.254, my problem is dhcp lease is almost full how do i expand my dhcp? ori will add >> next pool range? like 10.12.1.20-10.12.0.254 << is this correct?
You’ve basically assigned the entire /24, if you assign IPs outside of that range and a gateway within it the clients won’t be able to get to it. The cleanest solution is to grow the network by changing the netmask and then adjusting the pool.
