how to use extra channel frequency in mantbox 15ax there is limited channel can anyone help me for this
What do you mean exactly? Do you have the indoor/outdoor setting correct?
Or do you want to set a channel outside the standard bands? That cannot be done on this device, it only allows the standard channels to be used.
