I have 2 routers. They are connected only via WiFi and share the same net. Here are the details:
- R1 is in mode station bridge and is connected to DSL on ETH1. All works well when clients use it as gateway
- R2 is in mode ap bridge and has LTE stick in the USB. Again everything works well when clients is it as gateway
I have some servers connected via eth on both routers and everything works perfect. Nothing special in the routing, it’s practically vanilla.
I want to have the wan on R2 as the default so in the dhcp config I configure R2 to be the client gateway. I can’t figure out how to automatically fail over to R1’s wan when he LTE ot R2 is down.
I have added route on R2 so that R2 can ping R1 wan gateway IP, but when I add default gateway rule on R2 it says the R1 wan gateway is not reachable.
On client pc when pinging R1 wan gateway I get this:
ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1): 56 data bytes
64 bytes from 192.168.0.1: icmp_seq=0 ttl=63 time=2.733 ms
92 bytes from 192.168.1.1: Redirect Host(New addr: 192.168.1.2)
Vr HL TOS Len ID Flg off TTL Pro cks Src Dst
4 5 00 0054 53fc 0 0000 3f 01 a46a 192.168.1.241 192.168.0.1
