Dear All,
we are using our internal NMS system so we want to integrate the graph usage of particular IP so I want to know about how can i access the bandwidth usage data from Mikrotik router & make graph with MRTG.
Thanks,
Regards,
lucky
Dear All,
Thanks,
Regards,
lucky
you can use from an OID of queue you made for those particular ip’s
but make sure you has SNMP enable.
Paul
I think
/ip traffic-flow
is a better approach.
