Apple owns the entire 17.0.0.0/8 most things are located there.
To be certain you get it all connect to the services you want to redirect and monitor the IP address that you connect to. Start by blocking (Black hole the traffic with a route) them and keep retesting until you get them all black holed. Then change the black hole into a route out to your other gateway and retest.
