How the interface where to find “Rx> 10M” in the PPPOE connection?
I want to be a PPPOE link RX> 10M automatically disconnected.
Perhaps it is much better to set bandwidth limit for the client 10M to RX.
As user programs will try to use maximal available bandwidth, if there is more than 10 available, the disconnects will be very frequent.
So, my recommendation to use /queue simple for PPPoE-client, which will limit download/upload (RX is included).
Thank you reply.
Have been used QUEUES, but there are many individual users to send UDP packets, it sends quite normal, I am limited to 2M, but it has already sent a total bandwidth of more than 10M. I think it was a problem with the user’s computer, it is not repaired, I would like to upload data greater than the limit if they find the value of the PPPOE connection to disconnect them.
Not good at English, hope I have expressed to understand.
