my diagram
Since you don’t identify what the problem actual is, nor any troubleshooting steps taken… I don’t think anyone can help.
You need to take the time and provide a detailed breakdown of what the problem is.
sorry
the problem is in VPN i use l2tp/IPSec Head office can not ping to branch office
but branch office can ping to Head office
Okay, what are the private IP addresses that are used on each side?
What do your routes look like on each side of the VPN?
Head office ip : 192.168.88.0/24
ip vpn l2tp/ipsec : 9.9.9.9
branch office ip : 192.168.99.0/23
ip vpn l2tp/ipsec : 9.9.9.10
this script
/interface l2tp-client
add connect-to=xx.xx.xx.xx disabled=no ipsec-secret=“\E5/-\C0\B6\D8” max-mru=
1460 max-mtu=1460 name=xxxx password=xxxxxx use-ipsec=yes user=
xxxxxx
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add address=192.168.99.1/24 interface=ether5 network=192.168.99.0
/ip firewall mangle
add chain=prerouting in-interface=ether1
add chain=prerouting in-interface=ether2
add action=mark-connection chain=input comment=
in-interface=ether1 new-connection-mark=PORT1_conn
add action=mark-connection chain=input in-interface=ether2
new-connection-mark=PORT2_conn
add action=mark-routing chain=output connection-mark=PORT1_conn
new-routing-mark=to_PORT1
add action=mark-routing chain=output connection-mark=PORT2_conn
new-routing-mark=to_PORT2
add chain=prerouting dst-address=61.91.54.29 in-interface=ether5
add chain=prerouting dst-address=192.168.1.0/24 in-interface=ether5
add action=mark-connection chain=prerouting dst-address-type=!local
in-interface=ether5 new-connection-mark=PORT1_conn
per-connection-classifier=both-addresses-and-ports:5/0
per-connection-classifier=both-addresses-and-ports:5/1
per-connection-classifier=both-addresses-and-ports:5/2
in-interface=ether5 new-connection-mark=PORT2_conn
per-connection-classifier=both-addresses-and-ports:5/3
per-connection-classifier=both-addresses-and-ports:5/4
add action=mark-routing chain=prerouting connection-mark=PORT1_conn
in-interface=ether5 new-routing-mark=to_PORT1
add action=mark-routing chain=prerouting connection-mark=PORT2_conn
in-interface=ether5 new-routing-mark=to_PORT2
add action=masquerade chain=srcnat out-interface=ether2
/ip ipsec peer
add address=9.9.9.9/32 comment=Bangkok enc-algorithm=3des local-address=
0.0.0.0 nat-traversal=no secret=123456
/ip ipsec policy
set 0 disabled=yes
add comment=“Connect Bangkok” dst-address=192.168.88.0/24 sa-dst-address=
9.9.9.9 sa-src-address=9.9.9.10 src-address=192.168.99.0/24 tunnel=yes
add check-gateway=ping distance=1 gateway=61.xx.xx.xx routing-mark=to_PORT1
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_PORT2
add check-gateway=ping distance=1 gateway=61.xx.xx.xx,192.168.1.1
add check-gateway=ping distance=1 dst-address=192.168.88.0/24 gateway=9.9.9.9
