Hello Everyone
when i connect a dvr to the Mikrotik port it gives me this Error please see attached picture and CPU Spike to 50 + percentage and also Internet goes down
Please Help
Hello Everyone
Please Help
Anyone can Help will be Appreciated
thanks
So, have you increased it? IP → Settings → Max Neighbor Entries
Also, check IP → ARP when problem appears
Thanks a lot I will try it
the problem is still exist
Do i need to change something else on this IP settings
The problem only occur when i connect DVR on one of the interface on Mikrotik
Do i need to change some settings on DVR ???
When i Disconnect DVR every thing come to Normal
what traffic is coming from the DVR? maybe you are able to sniff it when it is connected.
and what happens with ARP table when you do that? we’re not telepathists
OK I will take a screen shot of ARP table when I see the issue again
also, what packets is VCR sending would be useful, as you can either filter them out or we can adjust neigbour detection.
