How to fix my code? comments turns to be equal to each other?
How to fix my code? comments turns to be equal to each other? what could be the problem?
heres my code
/ppp secret
:foreach item in=[find] do={
	:local prof [get $item profile]
	:local comm [get $item comment]
	:local profCom "10 MBPS old 599 test"
	:if (($prof) = ($profCom)) do={
	:local accNum [:pick $comm ([:find $comm "Number: "] + 8) [:find $comm " Plan:"]]
	:local cost [:pick $comm ([:find $comm "Cost: "] + 6) ([:len $comm])]
	:local bill ($cost + 899)
	:local billmsg "Acc Number: $accNum Plan: 10mbps Cost: $bill"
	[/ppp secret set [find profile="10 MBPS old 599 test"] comment=$billmsg]
	:delay 1
	} else={
	:log warning "hays"
on this image acct number and bill are different .
then when i run the code, they became same value
Please help, thankyou
is there anyone ? please help .
It seems that the issue is that the $billmsg variable is being overwritten in each iteration of the loop, resulting in all PPP secrets having the same comment. To fix this, you can modify the $billmsg variable by including the value of $item to create a unique value for each PPP secret:
:local billmsg "Acc Number: $accNum Plan: 10mbps Cost: $bill ($item)"
This way, the comment for each PPP secret will be unique and not equal to each other.
@tomislav91
It’s time you try to understand what is being asked before answering…
@akira463
When you have two different comments like this
“Acc Number: 2021022 Plan: 35mbps Cost: 599”
“Acc Number: 2021021 Plan: 35mbps Cost: 4507”
You must search the original comment, for example “Acc Number: 2021022 Plan: 35mbps Cost: 599”, for replace it with new comment with updated cost,
not generically the profile that have the user “10 MBPS old 599 test”,
but you already have the item index $item inside the cycle, you not need to search again, just set the value on index,
and with putting the profile in the [find] you do not need to check it again inside if is present the comment or not.
I can not test the script because I do not have such profile and users, but must be like this:
/ppp secret
:local profCom “10 MBPS old 599 test”
:foreach item in=[find where profile=$profCom] do={
:local accNum [:pick $comm ([:find $comm "Number: “] + 8 ) [:find $comm " Plan:”]]
:local cost [:tonum [:pick $comm ([:find $comm "Cost: "] + 6) ([:len $comm])] ]
:local billmsg “Acc Number: $accNum Plan: 10mbps Cost: $bill”
set $item comment=$billmsg
:delay 1s
Thankyou again , sir rextended , youre such a life saver!!. thankyou so much , i hope that youll never get tired of helping me :smiley: :smiley: :smiley: . Godbless!
Find the original comment by searching for a phrase like “Acc Number: 2021022” Plan: 35mbps Cost: 599", to update the profile with a new note reflecting the new price, rather than the generic “10 MBPS old 599 test”.
