Ok…On the other hand…
Do you know that if configuring other “band” to this new model Routerboard the TX/RX rate could be fixed? Maeby with other Transmission Protocol (nstreme, 802.11..)??
Thanks!!!
Thanks!!!
ohh no its a very bad issue.
I know there are many people never has changed data-rates but in my case i do it all the time to limit coverage or to get more stability
You are mistaking .n and .ac with nstreme, nv2.
802.11ac cannot be set to exact MCS and this is actually part of the protocol itself. You can however set the maximum MCS from Data Rates → Configured → VHT, but not less than MCS0-7. If you switch to .n then you can set an exact MCS from Wireless → HT MCS (you still need to set Data Rates to configured).
This has nothing to do with 802.11, nstreme or nv2.
some body who has a AC device can post a screen shot of winbox wireless interface data-rate tab and mcs tab or tabs???
to see options available before buying
Thanks for the answer;
I got it ![]()
