Can anyone assist to flash mini-pci cards with new firmware?
Need Firmware for NL-2511-MP to frequencies over 2.499GHz.
Thx
Thx
it seems this is senao card. I think this card is based on prism 2.5. You can only get extended frequencies only on atheros, i guess so.
regards
Thx N.
I have also tried the CM9 and a new card with 5413 chipset. Even the 8602 and SR2. All the same!
Frustrated!!!
Anyone has seen 2.5 till 2.6 Ghz? Please specify in which country!
Thx.
you need custom frequency license!!! Go purchase at mikrotik.com!! or wisp-router.com
hmm 2.5-2.7ghz use orinoco b/g pcmcia card
atheros 5212 I guess
Thx.
I have already purchased the frequency license upgrade, but it has given me only uptill 2.499 GHz on CM9 and that wlm54 or whatever card. Is there another upgrade for 2.5-2.7 Ghz? If that is the case, then our supplier is ripping us, as I specifically asked for an upgrade to support 2.5-2.6 Ghz.
Also, the reason we are looking for mini-pci cards instead of PCMCIA is that then we can use RB112 which is drastically cheaper than RB230 for the client side. It would be cheaper for us to install Wimax 802.16e with roaming and 80mbps throughput NLOS than RB230s lol.
Atheros 5212??? Any suggestions for more specification as Make, Product code, etc?
