How to Force Hotspot Users to use Specific DNS without touching Dynamic NAT Rules
Below script with your DNS and Ip addresses will help you to FORCE already configured hotspot and its users to use given DNS nameservers. I looked everywhere but couldn’t find a complete working solution. Then I did dome digging with the router settings and found this fix and it worked really good. no sweat!
Step 1. If you have a vpn(l2tp or pptp? use below commands to puch DNS traffic through your VPN)
/ip route add distance=1 dst-address=DNS_Nameserver1 gateway=l2tp-out or pptp-out interface
/ip route add distance=1 dst-address=DNS_Nameserver2 gateway=l2tp-out or pptp-out interface
Step 2. Disable Public DNS lookup from WAN port. (ether1 in this case)
/ip firewall filter add action=drop chain=input dst-port=53 in-interface=ether1-gateway protocol=udp
/ip firewall filter add action=drop chain=input dst-port=53 in-interface=ether1-gateway protocol=tcp
Step 3. NAT rules to Force Hotspot users to use given DNS Nameservers, chain=pre-hotspot rule pushes its rules before hotspot NAT rules executed. Really helpful when you already have 53 udp/tcp ports to 64872 ports Dynamic NAT Rules(which caused me lot of trouble)
/ip firewall add action=dst-nat chain=pre-hotspot dst-port=53 in-interface=bridge interface here protocol=udp to-addresses=DNS_Nameserver1
/ip firewall add action=dst-nat chain=pre-hotspot dst-port=53 in-interface=bridge interface here protocol=tcp to-addresses=DNS_Nameserver1
/ip firewall add action=dst-nat chain=pre-hotspot dst-port=53 in-interface=bridge interface here protocol=udp to-addresses=DNS_Nameserver2
/ip firewall add action=dst-nat chain=pre-hotspot dst-port=53 in-interface=bridge interface here protocol=tcp to-addresses=DNS_Nameserver2
/ip firewall add action=return chain=pre-hotspot in-interface=bridge interface here (important rule to work above NAT Rules, place this end of the chain)
Step 4. Finally You need to add 2 entries to your Walled Garden IP List under Ip/Hotspot/Walled Garden Ip List/Add
action=accept/server=your bridge interface/dst address DNS_Namesever1 and another entry for DNS_Nameserver2
Test this out and you are good to go. Hope this helps
Thanks!
Nice one. I suspect this will be good for DNS based control over which sites a user can or can not visit. I use openDNS for this.
