how to force the choice of connection to the base station with the best rssp
Hello
How to force the choice of connection to the base station with the best rssp?
iI I switch the external antenna to auto mode later both and back to auto mode
in the end, it will connect to the base station with the best RSRP.
It’s easy, just set it.
You can use cell lock…
https://help.mikrotik.com/docs/display/ROS/LTE#LTE-UsingCelllock
