Is it possible, at all, to force a PPPTP VPN over a given interface?
Let me explain the scenarion: A remote branch (to far to get to quickly) has a VPN over ADSL connection which is very slow. So I told them to buy a LTE router and use that to re-route some of the traffic over the LTE, and thus ease-off some of the load on the ADSL VPN.
The problem is, I need to connect back to the same VPN on this side (IP range 192.41.100.0/24) from that side (IP range 192.168.4.0/24).
I suspect the VPN connects over the pre-existing ADSL line, instead of the new LTE.
My routes are as follows:
pptp 0
LTE 1
ADSL 5
