pls sent to a step by step on how to formatt my routerboard rb333. yhanks
you don’t need to do it
why?
Just use:
/system reset-configuration
If you need to wipe it clean for all data, use the BIOS…
i would suggest to use netinstall tool to reinstall it, without saving configuration - that way ever configuration bit will be lost.
