How to gain 2db whit a simple welding
Hi friend, today I made a small change to my R52N.
I removed the standard U. FL connectors I soldered the wires directly on board.
I Link some pictures. From the tests I can attest that I have gained as many as 2 dB.
bye bye
Wouldn’t an R52Hn be an easier way to gain a few dBm? :slight_smile:
And then you could easily replace the radio if it ever failed.
Tom
There are no stupid ideas… just people…
  1. If the radio failed is simple replace radio and cable :slight_smile:
  2. I think R52Hn card is useless. Since his previous R52n a dual band already has its problems, because amplify these problems?
    A tip is to use R52n whit a good antenna. Yesterday I tested my R52n changed with the parables of the Jirous JRC-24DuplEX over a link of 10km and are able to get a stable connection whit as TxPower of 2db (awesome). So I suggest this solution.
In my opinion you lost some 2 dB :slight_smile:) You have big enough unshielded cable trace.
uhmmmm, can be a right supposition and I will correct the cable.
tnk u
