I press this script(http://forum.mikrotik.com/t/how-to-mail-me-if-isp-ip-change-pppoe/100611/1 if wan ip change, send e-mail notification, has been working satisfactorily. ip-per-acquisition are xx.xx.xx.2 ~ xx.xx.xx.12, how to make it in a fixed ip, such as xx.xx.xx.10, if not xx.xx.xx.10 , repeatedly dial, get to know xx.xx.xx.10. script can be used to achieve it, I hope to provide ideas. Thank you.
Please forgive my English, it comes from Google Translation.
Why not simply use ip > cloud?
If you have a web or other kind of server behind the mikrotik, you want to be available from outside, just create a CNAME (on your domain DNS) referring to the routerboard xxxxxxxxxx.sn.mynetname.net record.
Thank you pukkita, maybe I did not explain what I mean, I am not for easy access to my rb450g, in order to solve my upnp mapping. Wan ip address changes each time the interface, upnp on the failure, so I hope wan adsl connection interface can be fixed ip. Or is my thinking there is a problem, solve upnp problem, there should be better ways.
http://forum.mikrotik.com/t/need-script-for-upnp-after-reconnect/10845/1 topic is the same problem and I hope Solutions
What’s the 450G ROS version? firmware version?
That post is almost 10 years old… in addition, there have been lots of uPNP fixes.
rb450g v6.36.2 fireware is 3.24 . The latest version
Try this script. schedule it to run every 5mins. It will check if the ppoe has a new IP and if it does, it will remove the entries for upnp.
:global currentIP;
:local newIP [/ip address get [find interface="ppoe1"] address];
:if ($newIP != $currentIP) do={
/ip firewall nat remove [find comment~"^upnp.*"];
:put "ip address $currentIP changed to $newIP";
:set currentIP $newIP;
Be sure to change the interface=ppoe1 to match your ppoe name.
Thanks you ,@2frogs.Nice! it worked. But why not “/ip firewall nat remove [find dst-address = xx.xx.xx.xx]” or “/ip firewall nat remove [find dst-address = $currentIP]”, does not matter, this issue has been resolved. But why not put it to me, you want to get the ip address, it has been dial-up, I want to know the ip address, stop dialing, this purpose is to obtain a static ip address. If so, then you can achieve great.
I carefully observed the ip address range my adsl out (isp) obtained, xx.xx.xx.2 ~ xx.xx.xx.12, how to make adsl out to get the desired ip address, otherwise, have been dialing.
Sincerely hope you can help me solve.
I used the phrase “/ ip firewall nat remove [find comment ~” ^ upnp *. “];” After the wan ip change can delete the old upnp mapping.
