Hi all,
I need to get “avg-rtt” result of “ping” command in scripts. Is this possible?
Some one suggested “flood-ping” command. However, “flood-ping” will get “system is busy (12)” error if there is another instance running so it is not suitable for monitoring multiple endpoints.
Still interested in getting the avg-rtt as a local o global variable?
