I have a few servers running on my home network subnet. One of them is a 3cx PBX server. The office is on a different subnet and I need phones down there to work with the PBX. What I have tried so far is to connect to the PBX on my mobile (actual phones arent here yet) and I don’t seem to be able to connect to the server. I have seen some earlier posts about natting them but that probably will not work with SIP.
how many router do you have ?
If both Networks have the same Mikrotik as Gateway, it should work
It is the same router. The gateways are 10.10.1.1 and 10.10.3.1 respectively. Should I change the latter to 1.1 as well?
Don’t change anything
If it’s not working, send us the Config-File of the Router
/export hide-sensitive
I just got a new switch today, and I can’t seem to access the SwOS page from a different subnet. Posting config
https://hastebin.com/dagipuyuze.properties
