How to get Internet Access from a VRF
How to get Internet Access from a VRF having an interface within the same network prefix than an interface in the main routing table ?
The routing in this case does not work because the destination network in the VRF is the same as a connected network in the main routing table.
The same problem would occur if two VRF had the same network prefix, it would not be possible to route from the main table.
I think i should add the VRF route distinguisher in the main table static route to differentiate between the two routes. But how to do this (using static routes) ?
