HarvSki
September 22, 2004, 7:26am
1
I’ve a site where I can login to the MT router all my equipment at the site is connected to the UPS which is connected to the MT router via a serial connection.
I can see from this site http://us1.networkupstools.org/protocols/apcsmart.html
that if I could send @nnn (whenre n is tenth of a hour) I could ask the UPS to power cylcle the whole lot.
Maybe this should be a feature request?
sten
September 23, 2004, 10:31am
2
Look at: / special-login
I had one user setup to be able to login via ssh and talk to different types of equipment over the serial port.
GJS
September 25, 2004, 3:52pm
3
This is an interesting feature which sadly seems to be documentation free!
Can the serial port be assigned to a special-login user while it is in use by the UPS feature?
sten
September 25, 2004, 3:55pm
4
No, i overlooked that. However, had you had a second serial port, it would have worked.
HarvSki
September 25, 2004, 10:22pm
5
the PCs I use do have 2 serial ports…
GJS
September 25, 2004, 11:43pm
6
…but the UPS has only one…(presumably)
