How to get runtime information via script
Hi all,
Is it possible to get the runtime information via script?
For example, get the remote ipv6 address of the pppoe client interface:
Thanks.
Hello! Yes, it is possible with the next script, as an example I used the local address:
:local text1 "IP: $[put [([interface pppoe-client monitor DIGI once as-value]->"local-address")]]"
You can change the “local-address” with any other value, example: “mtu”, “uptime”, etc. Also, change “DIGI” with your pppoe client interface name, mine is named DIGI, yours could be pppoe-out1 if you didn’t changed it.
If you want to execute this via SSH, you need to replace the $[put with :put, for example:
:put [([interface pppoe-client monitor DIGI once as-value]->"local-address")]]
The result will be:
[admin@MikroTik] > :put [([interface pppoe-client monitor DIGI once as-value]->"local-address")]]
79.119.XXX.XXX -> my public IP address
[admin@MikroTik] >
Also, you can use the text in another command withtin the same script via “$text1”, for example, you can get the IP address and use it in a DDNS service that has ip update via url with the fetch tool.
This is exactly what i want, thank you so much.
I found that the execution in the script can be simplified to:
:local text1 "IP: $[([interface pppoe-client monitor DIGI once as-value]->"local-address")]"
or
:local text1 [([interface pppoe-client monitor DIGI once as-value]->"local-address")]
