Hi Folks,
I apologise if this has been answered elsewhere. I have looked but not found any info.
My Mikrotik x86 is in use as a web proxy. I have created a second store on a second disk that acts as the storage location for the web cache.
My problem is that I wish to graph disk usage but the mikrotik graphs only show disk usage for the primary disk.
How can I add other disks /stores to be graphed?
Regards
Alex.
I think it’s not possible now. why do you need this?
I want to be able to graph the disk used by the Web Cache.
I guess its not a really big deal, but if I can graph primary disk use then why not secondary? In my case the primary disk use is fairly static as it holds the RouterOS, some backup files and some scripts…
But I have set my Web Proxy Cache to Unlimited and so want to keep an eye on the second disks usage.
Thanks,
Alex
