how to hide my network
Cover it with a “cloak of un-connectability”
Sorry, couldn’t help it.
Can you be more specific?
Get it a fake moustache?
Or:
/int wireless set [/int wireless find] hide-ssid=yes
–Eric
hide from where?
I have 50 clients conected in my netwok, but I need hide all.
The clients, not a see it other
if they connect with wires through a hub or switch, then you can not do this - connections go through the switch and not through the router. some expensive switches maybe will be able to isolate the users, but this is not a RouterOS question anymore
I am sorry, but I think I was not clear enough.
I have 50 clients connected through wireless using the mikrotik, sharing internet.
Clients can see each other in the network and sharing files and printers. I don’t want it happen. I would like to remove this system.
At the Teletronics system, there is a command in the firewall that you can do this, but I cannot do it at the mikrotik system. Can you tell me how to do it? Is it possible? I need a clear information on this subject.
press the search link at the top - this has been discussed plenty of times over and over…
  1. default forwarding on the AP, off
  2. Firewall rules to drop packets from one client going to another
  3. even more simple, just firewall NetBIOS Ports (137-139 & 445)
discussions examples, and everything else you may or may not need, is on the forum.
yes, if you use wireless, set default-forwarding to off on the wireless interface.
Imho if a couple of users voluntarily add a route to access each other through gateway they will have access to resources.
If you reall want to block netbios i’d also to block these ports:
tcp & udp: 135,137,138,139
tcp: 445
better do what normis said
default-forwarding=off
if you set default-forwarding=off then all communications will go through firewall, so … you will be able to control this better. even drop the traffic.
Thanks for the help.
But how can I do this?
I don’t know the exact command to put there. I understood you have to block the ports:
tcp: 445.
firewall. RTM
