Hi we have purchased athros mini PCI wireless Cards. How to identify it is 200 or 400 mw cards.
Nothing is written on it and the Power is Not showing in Wireless Property.
The Chipset is AR5414A-001 is written
ASHISH
ASHISH
I found this description in Google:
WLAN High-Power 802.11a/b/g mini-PCI Module
(Atheros AR5414A / 400mW / Commercial Temp.)
You need to check the manufacturers website using the model number of the card. This the only way to know the power of the card. When you get to the manufacturers website , view the datasheet of the card to get the detailed specification of the card. If you do not know the manufacturer of thecard , then use the MAC address of teh card to track down the manufacturer. The first 6 digits of a mac address are unique to only one manufacturer. A simple google search will get the information
Hope this helps
