How to identify error with Catch run-time errors?
Hi, I have testing this code and it works, but the problem with large code is not can show wich is the error or the point of error:
:do {
      :put [:resolve www.example.com];
} on-error={ :put "resolver failed"};
:put "lala"
output:
resolver failed
lala
This is from http://wiki.mikrotik.com/wiki/Manual:Scripting#Functions
Anybody know how can I know the text error and the point of error?
Regards
Hi, normally other lenguages have properties or functions to identify the text error. Os this way for catch errors, when you are writing code for any script is very difficult found the error, and many times is needed deactivate al least to know the error becouse with this catch error you only know an error have ocurred.
The people of Mikrotik can look for any system to edit the scripts better than the script window, the letter is very small and is difficult to bleed the code and look for search for opening and closing brackets, can be much improved.
Regards
