Hello all,
I try to find at Google and this forum…but without success…
Is it possible to prepare some .CSV or another file with list of routers and import it into the Winbox?
Thank you very much,
Vladislav (CZE)
Hello all,
Vladislav (CZE)
This looks like you could get it to WBX file that winbox can import.
http://forum.mikrotik.com/t/feature-request-winbox-import-from-csv/86599/1
You could also use this tool, but be aware that the database is not encrypted so not sure if it would work in your environment. It can be stored on a network share and used by multiple people.
https://github.com/LCT-Jonah/ahk-mikrotik-toolbox
It can also be used for making scheduled backups via ssh and deploying router upgrades either manually or via Windows Task Scheduler.
