how to increase LAN port in R B 2011 L by using another R b (493) for example >>> because i want to load balancing more than 14 ADSL line … can i link R B 2011 L with R B 493 using Ethernet cable ???
You could use one port on the RB2011 and add VLANs to that interface then have each VLAN link to a different port on the 493.
Could you explain how to do that? please?
Have a look at this page:
http://wiki.mikrotik.com/wiki/Manual:Interface/VLAN
Outline for 5 ADSL modems: Choose an interface on each routerboard device to be the “trunk”. On both those interfaces add VLAN interfaces (Interface menu) with (say) VLAN IDs 10,11,12,13,14,15. On the 493 also make 5 bridges called something like VLAN10Br, VLAN11Br etc. Then for each bridge add 2 ports - the corresponding VLAN interface (e.g. VLAN 11 for bridge VLAN11Br) and an Ethernet interface that you will connect an ADSL modem to.
The remaining details depend on whether the ADSL modems are in briudge or router mode etc. Essentially the system above gives to a layer 2 path from the VLAN interface on the 2011 to the corresponding ADSL modem hung off a 493 Ethernet port.
thanks a lot for your support, I tried what you told me but no thing happened and I couldn’t bridge them at last … I spent many hours in vain. can you please tell me step by step? I really need it so much. if you like me to give you the routers IPs it’s ok . hope to hear from you soon
thank you
Please any body reply me
Try posting the configs that you have tried so we can comment on those.
RB 750GL will work as (Rb 2011)
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:2B:41:85 master-port=
none mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:2B:41:86 master-port=
none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:2B:41:87 master-port=
none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:2B:41:88 master-port=
none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:2B:41:89 master-port=
none mtu=1500 name=ether5 speed=100Mbps
/interface vlan
add arp=enabled disabled=no interface=ether5 l2mtu=1594 mtu=1500 name=vlan1
use-service-tag=no vlan-id=1
add arp=enabled disabled=no interface=ether5 l2mtu=1594 mtu=1500 name=vlan2
use-service-tag=no vlan-id=2
add arp=enabled disabled=no interface=ether5 l2mtu=1594 mtu=1500 name=vlan3
use-service-tag=no vlan-id=3
add arp=enabled disabled=no interface=ether5 l2mtu=1594 mtu=1500 name=vlan4
use-service-tag=no vlan-id=4
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set ether1 vlan-mode=disabled
set ether2 vlan-mode=disabled
set ether3 vlan-mode=disabled
set ether4 vlan-mode=disabled
set ether5 vlan-mode=disabled
set switch1_cpu vlan-mode=disabled
RB 433 will work as (RB 493)
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526
mac-address=00:0C:42:2D:37:AA mtu=1500 name=ether1 speed=100Mbps
no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2D:37:AB master-port=
no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2D:37:AC master-port=
/interface vlan
add arp=enabled disabled=no interface=ether3 l2mtu=1518 mtu=1500 name=vlan1
add arp=enabled disabled=no interface=ether3 l2mtu=1518 mtu=1500 name=vlan2
add arp=enabled disabled=no interface=ether3 l2mtu=1518 mtu=1500 name=vlan3
add arp=enabled disabled=no interface=ether3 l2mtu=1518 mtu=1500 name=vlan4
add arp=enabled disabled=no interface=ether3 l2mtu=1518 mtu=1500 name=vlan5
use-service-tag=no vlan-id=5
/ip neighbor discovery
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set vlan1 disabled=yes
set vlan2 disabled=yes
set vlan3 disabled=yes
set vlan4 disabled=yes
set vlan5 disabled=yes
On the 433 that is filling in for the 493 you now need to make 5 bridges and then 2 ports for each bridge. One port is the relevant VLAN interface and the other is the relevant physical Ether interface.
Hello, I use a dell switch with 24 ports, each port connecting an ADSL service, which corresponds to a VLAN interface, and a PC with X86 router OS, and two ethernet card in the pc only.
I use pcc load balancing to 5 vlan interfaces going to the my user, this configuration work fine.
if you prefer I can help you with the configuration.
Best regard.
Thank you very much for your support … you made me save alot of money and I did it finally, without your help I wouldn’t have done anything, thanks again ![]()
