How to increase the address pool for a hotspot created on VLAN?
Currently I created a hotspot on VLAN10. The address pool for this is 192.168.10.2-192.168.10.254. How can I increase/add more address pool to this hotspot? For example if all IP addresses in the above range is occupied then new IP can be assigned from the pool 192.168.2.2-192.168.3.254 or 192.168.4.2-192.168.4.254 or 192.168.100.2-192.168.100.254 so that there can be more than 252 users on the network at a time.
Any help will be appreciated.
Hello
you can use more ip address in ip pool but you should use bigger subnet
Are you sure increasing subnet will work?
