How to initially enable LACP?
I have an OPNSense firewall, which I’m trying to configure LACP to the Microtik switch.
Initially, I put the two firewall ports in LACP, and believe I caused a network storm. Went back and switched it to just on sfp+ port, which allowed me to login to my Microtik fine. But, I could not link aggregate both ports since one was already bridged. So, I shutdown the router, and am now stuck in a login loop.
How may I get into the Microtik so those ports are bonded?
Ok, the issue is one of the sfp+ cables is used as a bridge. I disabled the bridge, which caused problems. That let me bond both cables, though. Why is the bridge not being reassigned to the ethernet cable I temporarily setup through the router?
Looking at the bridge I don’t see an option for manually reassigning it. Is that done through sfp+ port 1?
