Hello, unfortunately this does not work
It is not only wireless-cm2 to give problems, I can’t even install the NTP package.
in the “files” tab I have “flash/ntp-6.24-mipsbe.npk”
If I click it, I get:
File Name flash/ntp-6.24-mipsbe.npk
Type package
Size 260.1 KiB
Creation Time Jan/02/1970 01:50:38
Package Name ntp
Package Version 6.24
Package Build Time Dec/23/2014 13:38:45
So it is recognised correctly.
RouterOS and all the other packages are version 6.24.
Weirdly the RB450 uploaded the fies in the root, while the AP uploaded them in the flash directory so I thought it was normal. I managed to move the files with Winbox and now they installed.
