how to install debian os on mikrotik container?
hi guys, i need instructions to install debian os on mikrotik container.
my plan is to install docker and portainer on debian, so that it can run some centralized services on mikrotik router.
my router : CHR or x86_64
anyone here can help me with this.
CHR already runs in VM environment, right ?
Put your Linux right next to it. No need to run it in Docker then.
Do not use the container for full-fledged OS installation.
As the others have said, containers are not VMs.
Atop that, you are also likely to run repeatedly into the several inherent limitations of container.npk, some of which may prevent it from working, others of which will merely make this scheme unsatisfactory.
