how to install NIC Isa on mikrotii
Dear all,
need your kind assist on installing 3Com 3c508 Isa on mikrotik ?
is it possible ?
Regards,
Zong
here you have some examples:
http://www.mikrotik.com/docs/ros/2.9/guide/driver
thanks normis for the reply,
already take a look the manual, but there was no driver for 3C508-isa only 3C509-isa.
driver > add name=3c508-isa io=0x280
error : Unknown value of name
need your further assist
Thx,Zong
does it work with 509?
driver > add name=3c509 io=0x280
I can add 3C509 but under interface > I can not enable it
Error:Setting flag failed
any other idea?
