How to install NPK over RS232 ??
Hi
I have a routerboard 150 minirouter
It has no mikrotik os installed - formatted nand
Ethernet port 1 and two are broken
I want to install routerOS 3.3 but netinstall don’t see this router board.
Is it possible to install routerOS only using rs232 cable.
I uploaded routeros-mipsle-3.30.npk over rs232 xmodem interface but i don’t now how to initiate the installation process
You can’t do that.
Why does netinstall not see this board? Did you enable net booting in the Bootloader settings? Did you follow the manual? http://wiki.mikrotik.com/wiki/Netinstall
Netinstall work only with port ethernet 1.
In my rb150 ethernet1 and 2 are broken
Give me a solution how to use netinstall whit other ethernet interface not eth1
sorry there is no other way to fix this then
if you have skills u can solder the flash nand of another RB and put in ur board. it will work. that is the lastest alternative
