Im new here, so i dont know mush about this. I have RB 532, with no OS on it. I connected it with PC (rs232) and acssesed to his BIOS. What should I do next, im not so good at networking so plz describe me step by step…
THANKS
THANKS
MikroTik RouterOS is preinstalled on RouterBOARD. probably you have RouterOS.
MAC-WinboxMAC-Winbox helps you to access the RouterOS.
To (re)install MikroTik RouterOS use netinstall.
there are some steps in polish language:
http://download.support.technologic.pl/MikroTik/FAQ%20MIKROTIK/Netinstall%20-%20RouterBoard%20500.pdf
maybe the screenshots will be helpfully for you
we have a manual in english too …
http://www.mikrotik.com/docs/ros/2.9/guide/netinstall
… but as suggested, RB500 already comes with an OS
there was OS on the board but someone has formated its NAND, thanks ill try with those pages, THANKS
I tried everything it just keeps displaying, ive downloader latest netinstall
RouterBOOT booter 1.11
RouterBoard 532
CPU frequency: 264 MHz
Memory size: 32 MB
Press any key within 1 seconds to enter setup.
kernel not found
trying bootp protocol…
please help
Make sure that
I’ve had some strange problems sometimes with a switch between the netinstall PC and the router. If nothing works, try a direct (cross-over) cable between router and PC.
Best regards,
Christian Meis
Every router comes with the OS instaled?
What is the licence? Level 4?
RouterBOARD comes with instaled RouterOS, default license level 4.
My RB532 came with license level 5 preinstalled from WISP. I’ve had it about 6 months or so.
apparently you paid for it
Thanks all and MT team,
Last year ago, i bought unwires package and they had good solution as our request.... and until now work fine... it came with 4 and 5 level....
again, Thanks Mikrotik. from it we has nice sleeeeeeep!!!
and i love you...
Probably. I work for an ISP and got the router from them so I’m sure they ordered it with level 5.
Mez
