As the subject stated the purpose of this post, can it possible that i intergrate a mikrotik with windows 2003 AD? where i want to use mikrotik as firewall as well as dhcp server and winodws 2003 server as domain controller as well as dns server.
I can’t see any problems at all. Just do it. If your set up is “simple” I see no problem. If the server is a domain controller, make sure the scope options are the same as what you would get on the dhcp server on the 2K3 server. I.e. Set DNS scope pointing to the DC server and domain name suffix the same as the server’s.
I want that Mikrotik give the ip to may clients (a.k.a act as dhcp server) and then mikrotik will automatically update the DNS records when giving out a new lease to a client computer.
Then I want to create the queue for each user on mikrotik in order to limit the user bandwidth.
then i want to implement all the filtering on mikrotik…
Please tell me, i can achieve this scenario? If yes, please point out me in right direction.
