how to integrate mikrotik dhcp with windows 2003 dns
As the subject says how to integrate mikrotik dhcp with windows 2003 dns?
I have Windows 2003 DC with DNS server and dhcp is running on Mikrotik , so can I do this that my Mikrotik DHCP server automatically updates DNS records on windows 2003?
thanks
Just set your 2003 dns server to use Mikrotik as it’s upstream DNS server.
@jandafields, you mean to say that i put the ip address of the mikrotik as forwarder in my win 2003 server?
Yes, your 2003 has to get DNS from SOMEWHERE (whether that is your ISP’s DNS Server, or OpenDNS, or whatever… so just have it use your Mikrotik as it’s DNS Server (and then have Mikrotik use whatever ISP/OpenDNS/Whatever DNS Server you want).
