Hello Guys!
I have a weird scenario, but I will try to make it simple to understand. I have a customer that works with video streaming. He use a kind of video encoder that sends multicast traffic over the network, so the connection was made to be simple: He take a video source and insert it on the encoder, the encoder (duhhh) encodes the video stream and send it to the network via multicast packets. While doing this, he uses a video decoder that receive the multicast traffic on the other side of the network and it’s done: The video stream on the other side goes out on the output of decoder normally, without any adictional setup.
But, guess what? If you want to have three video streams with 3 encoders + 3 decoders, you need to isolate the traffic between them because of the multicast, or you will end with alternating image source on decoders randomly.
This customer asked me if he can send 3 different video sources over a wireless link, so he can use 3 encoders plus 3 stations over one access point and separate the link, the first idea that came in my mind was: Well, lets use VLAN and voilá! Problem solved!
But I’ve faced a problem at this setup, as wireless doesn’t treat multicast very well..
I’ve created a bridge as usual between vlans for each interface, so it should work correctly, but the video streams leaks all over VLANS.
How to solve this scenario or make it work correctly? He need this setup because all those decoders will be not in a static point (cameraman + encoder)…
Regards!
