How to know which ethernet controller is which ether1-10
Hi guys. My X86 has 10 pcs following ethernet controller and 10 ethernet interface. How to show which controller is the which ethernet interface? Pls help
[otgonkhuu@MobiNetClassic] > sys resource pci pri
 # DEVICE   VENDOR                         NAME                               IRQ
2 05:00.1  Intel Corporation              82571EB Gigabit Ethernet...         11
 3 05:00.0  Intel Corporation              82571EB Gigabit Ethernet...         10
 4 06:00.1  Intel Corporation              82571EB Gigabit Ethernet...         11
 5 06:00.0  Intel Corporation              82571EB Gigabit Ethernet...         10
 6 07:00.1  Intel Corporation              82571EB Gigabit Ethernet...         11
 7 07:00.0  Intel Corporation              82571EB Gigabit Ethernet...         10
 8 08:00.1  Intel Corporation              82571EB Gigabit Ethernet...         11
 9 08:00.0  Intel Corporation              82571EB Gigabit Ethernet...         10
10 0d:00.1  Intel Corporation              80003ES2LAN Gigabit Ethe...         11
11 0d:00.0  Intel Corporation              80003ES2LAN Gigabit Ethe...         11
you may try :bulb:
/interface ethernet blink ether1
then check the ethernet card LED lights, which one is blinking.
you can do it to the other interfaces the same way
Thank you. But If I do blink ether1, of course my ethernet1 will blink. But I don`t know what controller behind my ether1. Any other idea?
