How to limit a VPN user's data rate?
Hey Everyone,
I need to give a third party access to my network through VPN. I have the user created and the VPN works fine. I am just having issues figuring out how to cap this user’s data capacity. Anyone know how I could accomplish this? I would like to limit this user to 5-10 Mbps when VPN’d into my MikroTik. The reason I need to limit them is because the user will have access to camera feeds so if they start streaming a lot of cameras, their data transmission will skyrocket and use a lot of the internet’s bandwidth. Any help would be greatly appreciated!
There is rate-limit setting in ppp profile.
Or the ability to create a queue autimatically.
Thanks! Yeah I found that setting. I’m having other issues now, but think I’m all set with the MikroTik configuration.
I’ve figured out how to set the limits for the VPN user. Now if I log in as that user and exceed the limit the VPN connection drops. Is there anyway that I can keep the VPN connection established, but drop packets instead?
Use the second option I mentioned - dynamically created queues, configured on the next tab right there in the ppp profile.
I appreciate your help so far. I created a simple queue limiting upload/download at 10M for the specific VPN connection. However once I connect with that VPN user and stream 9 cameras, i get more than 10 Mbps easily. So I do not think I set up the rule properly. Check out this picture.
Just tried it, with l2tp works as it should.
Do you see any traffic matching the queue?
I think you need to create a static “PPTP Server Binding” for this user to use as a queue target.
Or you can try automatically created queues from ppp → profiles → profile → queue tab
Got it working properly now. Thanks for your help!
Great! You are welcome :slight_smile:
