How to limit bandwidth to an IP?
I repost this question, because i think this question related to General Networking (previously i put this question at Scripting)..
Ok, at my office many employee access http://www.myspace.com, http://www.friendster.com, etc. Actually, they already access those sites after office hours, because i blocked them all in office hours.
Those sites really waste our internet bandwidth.. well, i already did bandwidth limiter on each IP, but almost all IPs (15 of 25) access those sites and it make very long queue.. do you know what i mean, the green icon become red in queues.
Of course it affect other user.. because i can not divide bandwidth equally.. we got 300 to 384 kbps (ADSL), and each IP got 24k of download.. so 24k x 15 = 360 kbps! well, other internet connection become slow.
I really need to limit bandwidth to friendster.com, etc..
I already tried below, but doesn’t work :frowning:
0 name=“queue-test” target-addresses=172.168.100.231/32
dst-address=203.x.x.x/32 interface=all parent=none direction=both
priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/24000
total-queue=default-small
So, i want to limit connection from 172.168.100.231 to 203.x.x.x at 24k
But the simple queue doesn’t work… i already move the chain to top of the list
but, i can limit all connection from that IP and it works! I use below at the moment…
1 name=“queue-172.168.100.231 (Jack)” target-addresses=172.168.100.231/32
dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8
queue=default-small/default-small limit-at=0/0 max-limit=16000/24000
I already tried this too:
subnet mask 255.255.255.0 or 24 on 203.84.155.150 and mikrotik force it to 203.84.155.0, well it’s ok for testing.. so will affect to all ip in that subnet, once again.. it’s ok for testing.
dst-address=203.84.155.0/24 interface=all parent=none
queue=default-small/default-small limit-at=0/5000
max-limit=0/5000 total-queue=default-small
but still, the bandwidth limiter for that IP doesn’t work.. actually on that IP / site there is bandwidth tester and it’s not limited!.. from proxy i can see the IP for testing bandwidth is correct (203.84.155.150). So, where is the problem?
dst-address=203.84.155.150/32 interface=all parent=none
it’s same! the bandwidth limiter doesn’t work!
I need assistance!
then i tried mangle the connection, mark the packet from that IP, then limit it
ip firewall mangle
6 chain=prerouting src-address=172.168.100.231
action=mark-connection new-connection-mark=clients-test
passthrough=yes
7 chain=prerouting dst-address=203.84.155.150
connection-mark=clients-test action=mark-packet
new-packet-mark=packet-test passthrough=yes
queue simple
packet-marks=packet-test direction=both priority=8
queue=default-small/default-small limit-at=0/24000
max-limit=0/24000 total-queue=default-small
i see there is outgoing traffic on Upload Rate and Uploaded Bytes, but there is no traffic from Download Rate and Downloaded Bytes… well, i already tried other settings, but still there is no traffic for Download :frowning:
I believe if there is incoming traffic (Download), the bandwidth limiter will work.. any idea??
please help me :slight_smile: thanks.. :frowning: :frowning:
Have you tried to make 2 queues? If you are doing NAT maybe you can try incoming traffic from 203.84.155.0 to put in one queue and outgoing traffic from your network to another queue and naming exact interface where that traffic will go through…
