I’m bit confuse about how to provide speed limits to users in usermanager, will I have to fill rx tx for every users individually?
thanks
thanks
I’m desperately waiting for profile field update because i have 2 start using user manager.
You can do this Under Users-Add User- Rate limit and choose the RX and TX rate you desire for the user. You can also apply this to batch users created
Hi all
I’m donig that but when limit the user by the Rx and Tx the invalid user name or password message appear to user when he’s try to log on until i was remove the limitiation, then can logon successfully.
i don’t why this happen
dear
u can do that by limit the profile of your services such as a deafult profile in hotspot or at the ppp profile in the limits tag
then put your Rate Limit (Rx/Tx) such ad 64K/128K.
u can donig the same in the the hotspot user profiles
regards
