I used to limit pppoe user with rate-limit in ppp profile. just the simpe to limit the tx/rx / user. The thing i want to ask is what about this :
i do not want to limit each user, but i have total 256K to share with the all users login to my radius. U can imagine i set the pcq with download rate 256k to limit all users.
Hi, I tried something similar, following the pcq examples in the MT reference manual and wiki.
I tried something like the following
Mangle rules for packet mark based on dst-address-list (for download):
/ip firewall mangle add chain=prerouting dst-address-list=my_addr_list action=mark-connection new-connection-mark=conn_down comment=“Connection Download” passthrough=yes
/ip firewall mangle add chain=prerouting connection-mark=conn_down action=mark-connection new-connection-mark=mark_users_down comment=“Packet Download Mark” passthrough=no
Queue Tree (Parent)
/queue tree add name=Download parent=Local max-limit=256K (in your case)
Queue Type (PCQ)
/queue type add name=pcq_down kind=pcq pcq-classifier=dst-address
Queue Tree (Child)
/queue tree add parent=Download queue=pcq_down packet-mark=mark_users_down
My problem was (and still is!), that by using Local interface as parent of the download queue (i.e., the interface where I have the pppoe access concentrator), I’m not able to see any traffic passing through the above pcq queue. So I tried using global-out or global-in as Download parent queue, but with decreasing performance result.
Finally, I switched back on using only the dynamic simple queues created based on the pppoe profile…
If you try and have better results … I’m very very interesting on it…
Nobody had the problem to use pcq for sharing download bandwidth, having pppoe access concentrator in the Local interface? It is a problem of the mangle chain to be used when marking packets?
Following the exact steps in the reference manual it seems not to work with such a configuration (PPPoE server in the Local interface). For my experience, it seems that using global-out as parent instead of Local, affects the overall performances, because queues apply also to the upload side.
If someone solved this issue, it could be very helpful…
Thanks.
